Activity Forums Media 100 Using G5 with SATA Drives as target for digitizing
  • Using G5 with SATA Drives as target for digitizing
    Posted by Henry Blood on August 24, 2006 at 10:28 pm
    Until I get a Media 100 HD system I’m thinking about using a Media 100sw equipped G5 quadcore with 2 internal 500GB SATA drives booted as a Firewire target to digitize from M100i on a G4 dual 500 with 1 GB RAM.
    Would this provide enough throughput for SD?
    I’m hoping to stripe the 2 500GBs together.
    HB
    Henry Blood replied 20 years, 1 month ago 2 Members · 2 Replies
  • Scott_f
    August 25, 2006 at 12:23 pm
    that’s a good question. I don’t think it will matter if you have the sata drives striped. It couldn’t hurt, but I don’t think you’d be able to use that as the G-5’s system drive(I recall something about not being able to boot to a striped drive or something). I
  • Henry Blood
    August 25, 2006 at 12:35 pm
    Yeah HD Suite although it’s overkill at this time. Of course, a dual 500 G4 with 1GB of RAM was overkill for me back in 1999.
    Thanks for the tip about booting to a striped drive – I’ll check it out. Seems like I’ve heard that the target disk is the system disk also, so striped may not work as a target disk if it can’t be the system disk.
    HB
