Activity Forums Blackmagic Design Using for Decklink *progressive* SD output from Premiere?
  • Using for Decklink *progressive* SD output from Premiere?
    Posted by David Ross on January 8, 2014 at 2:05 pm
    Hi all,
    Any suggestions for the best way to get progressive SD media or progressive SD timelines in Premiere CC to play out through Decklink to my external monitor?
    This all works fine in FCP 7 – possibly because FCP sends in interlaced signal to the Decklink, regardless of the clip/timeline field settings?
    David
    Mac Pro 10.8.5
    Decklink HD Extreme 3D+ (driver 9.9.3)
    (Monitor: JVC DT V24G1, connected by SDI)
    Premiere CC (7.2.1)
    David Ross replied 12 years, 7 months ago 1 Member · 1 Reply
  • David Ross
    January 14, 2014 at 5:35 pm
    Just in case anyone’s interested, I solved the problem by rolling back to driver version 9.9.2.
    Now I just need to get a working output for 720p @ 25fps & 29.97fps…
    D.
