Activity Forums Apple Final Cut Pro Legacy Using footage in After Effects that was captured from FCP 5…shows white
  • Using footage in After Effects that was captured from FCP 5…shows white
    Posted by Joshua Rule on December 14, 2005 at 7:53 pm
    There was HDV footage captured on a box that has FCP 5. I only have FCP 4.5 and I need to take the footage and bring it into After Effects. I assume that I don’t have the correct codec or something.
    Is there somthing that I can download so that I can view that footage in After Effects? Is there another process that I woul dneed to go through?
    Josh
    Todd Beabout replied 20 years, 8 months ago 2 Members · 1 Reply
  • Todd Beabout
    December 14, 2005 at 9:57 pm
    You will need QuickTime 7 in order to view HDV on your computer. I just checked, and HDV works in AE 6.5 running on Tiger.
    A workaround would be to either buy QT7Pro and export an image sequence, or get the guy that has FCP5 to do it for you. Then pull the image sequence into AE and run with it.
    -Todd Beabout
    Vazda Studios
