Activity Forums Apple Final Cut Pro Using Final Cut Pro X with Motion 5 for Keying
  • Using Final Cut Pro X with Motion 5 for Keying
    Posted by Mark Eskey on August 22, 2011 at 7:07 pm
    I am using Motion 5 to get a great key on some footage because the results are far better than though Final Cut Pro x’s keyer. Is there a way that I can work through Final Cut Pro X to apply my keys in Motion 5 or do I need to do all of my keys in motion then render and export all footage back into Final Cut Pro X which is a real hassle? Thanks.
    Mark Eskey replied 15 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    August 22, 2011 at 9:53 pm
    [Mark Eskey] “or do I need to do all of my keys in motion then render and export all footage back into Final Cut Pro X which is a real hassle? “
    Yes. No direct link from motion to fcpx.
    Jeremy
  • Mark Eskey
    August 23, 2011 at 12:01 am
    That is what I thought. Thank you very much for your response.
  • Greg Gilpatrick
    August 23, 2011 at 2:35 pm
    There is a Keyer in the FCP X effects browser. I don’t have Motion 5 but it looks like it is the same one pictured on Apple’s Motion web page. Even if it is not, I think it does a pretty good job, at least for stand-in comps.
  • Greg Gilpatrick
    August 23, 2011 at 2:41 pm
    Based on what I see in this video https://www.youtube.com/watch?v=-rSnqR1bs7s
    FCP X and Motion 5 have the same basic Keyer but FCP lacks the Advanced options.
  • Mark Eskey
    August 23, 2011 at 3:06 pm
    Thanks for your responses. Unfortunately the keyer in FCPX is a really scaled back version compared to motion 5’s keyer. There are many advanced options that can make the difference between a half decent key and a really great key. I guess I will just use motion and export it back to FCPX.
  • Pat Harris
    August 25, 2011 at 3:33 am
    Try
    File>Publish Template. I was able to take a logo I made and bring it right into FCPX. Although it counted as a generator so I’m not sure if this is what you want to do, if you have a bunch of clips or not. Although it may help if it is just one.
    Pat Harris
    http://www.CinematicDSLR.com
  • Mark Eskey
    August 25, 2011 at 2:05 pm
    I’ll give it a try. Thanks.
