Activity Forums Avid Media Composer Using Film Scribe for the first time.
  • Using Film Scribe for the first time.
    Posted by Dan Crouch on February 22, 2010 at 9:16 pm
    Please help.
    I have cut a sequence on Avid Mediacomposer.
    The sound mixer wants an XML file of the sequence, rather than an edl.
    I’ve never used this before.
    I have successfully ‘opened’ the sequence. I can select the video, audio 1-6 etc and all the options.
    But the ‘save as’ is grey and I can’t save it.
    Please can anyone tell me what i am doing wrong?
    Thankyou in advance,
    Dan.
    Michael Phillips replied 16 years, 7 months ago 2 Members · 3 Replies
  • Michael Phillips
    February 23, 2010 at 2:09 am
    Did you do a preview first? Then save as. Also, althugh it can generate an XML, that does not mean that a system supports it. Where is this XML going once generated?
    Michael
    Michael Phillips
  • Dan Crouch
    February 23, 2010 at 8:20 am
    Thanks for the post Michael.
    I have just previewed it first and it has allowed me to ‘save as’
    It does however come out as a simple text file, is that right?
    It is for a pro tools audio mix.
    Cheers,
    Dan.
  • Michael Phillips
    February 23, 2010 at 4:26 pm
    Yes, XML is a language with a defined format represented as Text. But Pro Tools does not support XML, it does do OMF and AAF. I am curious to know why there is a request for the XML. Pro Tools does support iXML which is the defined specification of the file based production audio recorders.
    Michael
    Michael Phillips
