Activity › Forums › Adobe Illustrator › Using Fill w/Paintbrush Tool
  • Using Fill w/Paintbrush Tool
    Posted by Jake Huddleston on October 15, 2009 at 3:49 am
    I am new to Illustrator, and I have set a color fill, but it only works when I use tools like the shape tool. How do I get a color to fill in the middle when I use the paintbrush tool and close it off? Thanks!
    John Mensinger replied 16 years, 11 months ago 3 Members · 2 Replies
  • Vincent Rosati
    October 15, 2009 at 4:50 am
    Paint Brushes are editable within the Brushes palette. If you want to edit the color, drag the brush onto the artboard, change the color, than drag that object back to the Brushes palette to create a new brush with the new colors.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • John Mensinger
    October 15, 2009 at 1:03 pm
    Jake, after drawing your closed shape with the brush, use the Pick Tool, (black arrow) to select it. Then, click the Fill side of the Fill/Stroke proxy at the bottom of the tool panel to bring it to the front, making Fill active. Then choose a swatch or set a color in the color panel.
    John M:
    All of the vim with none of that annoying vigor.
