Activity › Forums › RE:Vision Effects › Using FieldsKit with 59.94i HD footage
  • Using FieldsKit with 59.94i HD footage
    Posted by Scott Jones on February 4, 2007 at 10:29 pm
    I’m trying to de-interlace some 1080i footage shot at 59.94 with FieldsKit prior to slowing it down in Twixtor. I set up my precomp at 59.94, applied FieldsKit and selected the 2X FPS, 1 Frame Per Field option, as seems to be the conventional wisdom. The result is I only get a new frame every other frame and when I slow down the deinterlaced comp with Twixtor I get stuttery motion. I’ve found I get much better results by keeping my precomp frame rate at 29.97 and using the 1 Frame Per Frame option. Why is this?
    Scott
    Pierre Jasmin replied 19 years, 7 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    February 5, 2007 at 4:36 pm
    What application are you running in?
    I suspect you are dropping a 59.94 FPS comp into a 29.97 comp and are not setting Input Frame Rate to 59.94 in Twixtor.
    Could be something else, maybe the easiest for you is to send a project to techsupport@revisionfx.com (3 frames of source media should be enough here for that)
    Pierre
  • Scott Jones
    February 5, 2007 at 5:16 pm
    I’m working in AE7. Yes, I’m dropping a 59.94 into a 29.97 comp and setting the input frame rate in Twixtor to 59.94. I’ll send a project as soon I get a chance.
    Thanks.
  • Pierre Jasmin
    February 6, 2007 at 8:07 pm
    In case, another thing that can happen, if in the precomp you did FieldsKit then in Twixtor you set Input as No Fields
    Pierre
