Using fields to trigger animated texture?
Hi
I wondered if, for example you have cloned objects in grid array with animated texture (octane material with animated exr sequence), and you want to use field to move, or use deformers on these objects, but also trigger texture animation with the same field. is it possible?
Thank you
