Activity › Forums › Maxon Cinema 4D › Using Fields to Control the “Connector” Object’s Strength in a Voronoi Fracture
  • Using Fields to Control the “Connector” Object’s Strength in a Voronoi Fracture
    Posted by Hayden Martin on December 4, 2019 at 4:11 pm
    I’m looking for a way to create a realistic way of breaking a voronoi fracture apart with fields. I have attached a file with some xpresso which should make sense regarding what I’m hoping to do…
    Ultimately, it would be amazing if you could control the the connector strength for each chunk of the Voronoi Fracture. It would be even better if the noise field you pipe into the Xpresso would actually stick to the fracturing object too, so you could create fracture “growth” effects
    Would love to see a solution. Maybe this can be built in for C4D R22
    file is here:
    https://gofile.io/?c=glBOu4
    Hayden Martin replied 6 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
