Activity Forums Compression Techniques Using ffmpeg’s audio compressor/expander
  • Using ffmpeg’s audio compressor/expander
    Posted by Chiq Garcia on November 14, 2013 at 3:57 am
    I would like to share my personal remedy for videos/movies with barely audible ‘whisper dialogues’ followed by deafening explosions. While there is no one-size-fits-all setting for compression, I am hoping that this at least points you in the right direction or that you find it practical.
    example (stereo):
    "C:\ffmpeg.exe" -i "C:\InputVideo.mp4" -vf "scale=512:384, setsar=1" -af "compand=0 0:1 1:-90/-900 -70/-70 -21/-21 0/-15:0.01:12:0:0" -c:v libxvid -b:v 800k -r 24 -c:a libmp3lame -b:a 128k -ar 48000 -ac 2 "C:\OutputVideo.avi"
    translation:
    audio filter, compand, attack 0, release 1, -90 db in/inf out (gate), -70 db in/out, -21 dB in/out, 0 dB in, -15 dB out, soft knee default 0.01, 12 dB makeup gain, input level 0 dB, lookahead 0. Nasty transients seem to ‘escape’ the compressor if you omit “-90/-900” (I don’t know why).
    If this functionality had a GUI, it would probably resemble Adobe Audition’s dynamics processing (comes with a graph).
    Learning audio compression is tricky, and I found myself learning it and then re-learning it a couple more times. I guess it would be a dream come true if ffmpeg supported VST plugins like tube-saturation/brickwall limiting (e.g. Ferric TDS).
    For a convenient ffmpeg GUI, google: “en masse, batch processor for videos” and follow the yo*tub* link.
    En Masse ~ batch processor for videos
    https://www.youtube.com/watch?v=6pSH8lQZpRQ
    Stephen Dixon replied 12 years, 10 months ago 2 Members · 1 Reply
  • Stephen Dixon
    November 14, 2013 at 11:26 am
    Thanks for the tute. For a slightly more user friendly command line audio processor try sox. I usually extract audio, process in sox and remux.
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
