Activity Forums Apple Final Cut Pro Legacy Using FCP to create an bump with an alpha channel
  • Using FCP to create an bump with an alpha channel
    Posted by Steve Cohen on March 5, 2007 at 3:16 pm
    How can I create an animation or bump with an alpha channel in FCP.
    The final product is going to be a QT file that is placed on our SAN server and then rolled in live into a shoot that we will be doing.
    We are using BUGtv to playback the QT clips.
    I want to be able to create a bump element with a transition the will wipe back to the studio, but I don’t want my TD to have to match the wipe of the element, I want to create an alpha channel or put it over “Negative Black” for him to pull a key and when the element is over is goes bay to the studio automatically.
    Thanks;
    Steve Cohen
    Editor
    O2 Media Inc.
    Jeremy Garchow replied 19 years, 6 months ago 3 Members · 3 Replies
  • Peter Wiggins
    March 5, 2007 at 3:39 pm
    Steve,
    Most transitons on vision mixers come from a hard disk store or two Profile channels or similar.
    The only codec that supports an alpha in FCP is the animation codec. So, either kick out a tiff/targa image sequnce that a hard disk recorder can playback or make a key & fill for a synced two channel replay. I doubt if your replay cahnnel will be able to play an animation movie – the card won’tt either.
    Peter
  • Steve Cohen
    March 5, 2007 at 4:08 pm
    Thanks Peter;
    After doing a little more reading and testing I found out that FCP will treat the black background (being the area that does not have any video coving it) as an alpha channel if you export the clip as a Quicktime Conversion using “None” for Compression Type and “Millions +” as Compressor depth.
    This will import back into FCP as a single movie clip with the black space being the transparent.
    Thanks again;
    Steve Cohen
    Editor
    O2 Media Inc.
  • Jeremy Garchow
    March 5, 2007 at 7:46 pm
    …and you sequence should NOT be rendered before you export and you should no video or graphics in Video track 1.
    Jeremy
