Activity › Forums › Apple Final Cut Pro Legacy › Using FCP 7 with Kona 3G for 444 edit to tape
  • Using FCP 7 with Kona 3G for 444 edit to tape
    Posted by Patrick Devine on November 13, 2013 at 4:50 am
    Hi there,
    I am trying to create HDCam SR 444 rgb masters using final cut 7 and a kona 3G card for mastering and edit to tape.
    The files are apple pro res 444 that were created from a color session using davinci resolve.
    Everything seemed to be working fine, but when I double checked my external dual link HD sdi scope, my levels are being lifted 3 or 4 ire from what the davinci resolve is outputting.
    I know the files are good and have double checked them coming out of resolve to the scope and I have tried what I believe to be every concievable combination of settings in FCP, but I continue to get undesirable gamma shifts In The out put from the kona card.
    Does any one have any insight into what is causing this shift?
    What A/v output settings in FCP will give me a 1 to 1 output to what is in the file.
    Any help would be greatly appreciated.
    John Fishback replied 12 years, 10 months ago 2 Members · 1 Reply
  • John Fishback
    November 13, 2013 at 3:13 pm
    I don’t have an answer, but call AJA tech support. They’re great.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
