Activity Forums Adobe Premiere Pro Using Extracted Image from Photoshop
  • Using Extracted Image from Photoshop
    Posted by Rick Sullivan on January 11, 2007 at 8:49 pm
    I’ve extracted the background from a still photo in Photoshop, but when I bring it into Premiere Pro 2.0 the white background comes with it. How can I import ONLY the image that I’ve extracted and NOT the background?
    Phocas Kroon replied 19 years, 8 months ago 3 Members · 6 Replies
  • Phocas Kroon
    January 11, 2007 at 11:03 pm
    In Photoshop copy the still to a new file with a transparent backgroud.
    Remove the white background and use this file in Premiere.
    Good luck
    Phocas Kroon
  • Rick Sullivan
    January 12, 2007 at 12:33 am
    Thanks Phocus! That worked! But I’m guessing I could have saved a step somewhere in the process. I’m trying to learn new and better ways to utilize stills in my videos. Was there something I missed in Photoshop when I first made the extraction that might have helped?
    I’m also trying to learn 3D effects for stills in After Effects. The going is slow!!!!
  • George Socka
    January 12, 2007 at 1:30 am
    Before you delete the background – before you do anything in fact, double click the layer called background ( in the layer pallet on teh right) to convert it to a real layer. Then whatever you delete by whatever method – magic wand, eraser, will reveal the transparent background. And be transparent on PPRO. Mac clicking may be something else – same result.
  • Rick Sullivan
    January 12, 2007 at 2:46 am
    George Socka you rocka! I just did what you said and it was a heck of a lot easier than what all the books I’m thumbing through are telling me! thank you!!
  • George Socka
    January 13, 2007 at 2:38 am
    Can I frame that?
  • Phocas Kroon
    January 13, 2007 at 2:53 pm
    Yes, you can!
    Recently I have made an animation with about 500 drawings using my method.
    Your method is much much better and saves a lot of time.
    Thank you.
    Phocas Kroon
