Activity Forums VEGAS Pro Using external firewire drive
  • Using external firewire drive
    Posted by Mahesh Upadhyaya on May 29, 2006 at 9:12 am
    I am looking to get a laptop.(Sony VAIO FJ3S). It has only one firewire port. The answer to this may be quite obvious but:-
    can I daisy chain external firewire drive and camera so that I can capture to external HDD as well use the camera as preview deice.
    Regards
    Mahesh
    https://www.crestvideo.co.uk
    Mahesh Upadhyaya replied 20 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    May 29, 2006 at 2:31 pm
    I do. I’m using the following setup:
    Computer -> firewire -> Hard Drive -> firewire -> deck
    I can capture from the deck to the firewire drive.
    Edward Troxel
    JETDV Scripts
  • Mahesh Upadhyaya
    May 29, 2006 at 4:05 pm
    Thanks Edward. That’s what I am hoping to do. I am hoping to use laptop to keep’my hand in’ whilst I take more breaks away from the edit suite.
    Regards
    Mahesh
  • Gary Kleiner
    May 29, 2006 at 4:26 pm
    You should also consider using USB2 drives/enclosures.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Mahesh Upadhyaya
    May 29, 2006 at 10:53 pm
    Thanks Gary. Is USB2 fast enouh for capture / preview?
    Regards
    Mahesh
  • Edward Troxel
    May 30, 2006 at 2:30 am
    USB2 is definitely fast enough. It will take more CPU resources, though. You can try it using both USB and Firewire and see which you like best.
    Edward Troxel
    JETDV Scripts
  • Gary Kleiner
    May 30, 2006 at 2:30 pm
    USB2 is actually slightly faster than firewire. I switched the majority of my external enclosures to USB and often have 5 or 6 drives hooked up to my destop, or 3 or 4 hooked up to my laptop.
    Gary Kleiner
  • Seth Bloombaum
    May 30, 2006 at 4:49 pm
    Mahesh, daisychaining camcorders/decks and FW drives does not work always. As I understand it, there are two different FW protocols that the deck and drive use, and not all cards run them simultaneously. But many do.
    Several ways to deal with this if sharing doesn’t work: a second firewire card on a desktop. A PCMCIA FW card on a laptop ($35 USD?). A USB2 drive. I use drive enclosures with both USB2 and FW, but usually have them hooked up as USB2.
  • Mahesh Upadhyaya
    May 31, 2006 at 11:52 am
    Thanks guys for all the help.
    I never (never) appreciated that one could have FW and USB in the same box. I was also surprised to learn that USB2 is faster than FW.
    I am going to hide in a corner and read up on external HDD interfaces. I am ashamed to say that I never fully understood USB interface. Okay back to Google.
    Regards
    Mahesh
