Activity › Forums › Adobe After Effects Expressions › Using external CSV data to power keyframes
  • Using external CSV data to power keyframes
    Posted by Matthew Ingram on June 1, 2017 at 2:04 pm
    hi there
    almost BUT NOT QUITE a double post here (apologies) think i may have posted the last one i the wrong forum
    is there a way i can reference an external CSV file (a string of data measured 30 times per second) and use it to generate animation in after effects?
    thanks in advance.
    Matthew Ingram replied 9 years, 4 months ago 2 Members · 3 Replies
  • Thomas Hannen
    June 1, 2017 at 2:18 pm
    Hi Matthew,
    Any keyframe data from AE can be copied and pasted as text into a text editor. Equally, if the text is formatted correctly, any text from the text editor can then be pasted back into the keyframe layer that it came from. So you could use this method to create some keyframes on a slider control, paste them into TextEdit, then continue the formatting of the text as shown in the text file using your own data. Bear in mind you may have to tweak your data to fit a range that makes sense on screen – either beforehand in another application, or after using Expressions. Hope this helps.
  • Thomas Hannen
    June 1, 2017 at 2:19 pm
  • Matthew Ingram
    June 1, 2017 at 10:29 pm
    thanks thomas – that was really helpful
