Activity › Forums › Adobe After Effects Expressions › Using Expressions to animate smooth light movement
  • Using Expressions to animate smooth light movement
    Posted by Cameron Crook on August 13, 2011 at 12:50 am
    Hi, I am trying to figure out how to use expressions to animate a light with smooth movement. I am using the light as an emitter and don’t want to manually animate it, because I have a extremely long clip. The wiggle function is out of the question because its movements can be rough and sharp. I am trying to have the light to emit particles that are evenly space from each other while moving in 3D space. Any help is appreciated.
    Tylor Larson replied 15 years, 1 month ago 3 Members · 2 Replies
  • Stefan Hinze
    August 14, 2011 at 1:49 pm
    hey,
    give the wiggler a chance – maybe you set the “wiggles per second” to 0.5 or lower, so there will not be sharp movemend
    wiggle(0.5,400)
    greetz
    (take a step back, to see the bigger picture)
  • Tylor Larson
    August 23, 2011 at 9:35 pm
    https://jjgifford.com/expressions/basics/interpolation.html
    this is a link to add easing to your expression… maybe adding this to a wiggle might smooth things out enough. sorry don’t have time to test it… good luck
