Activity › Forums › Adobe After Effects Expressions › Using expression to reverse animation done by expressions?
  • Using expression to reverse animation done by expressions?
    Posted by Eunice Wong on February 10, 2021 at 3:35 pm
    Hi, I will try my best to explain what I would like to do.
    Basically, I am trying to create a mogrt for a lower third, and I want the Premiere Pro user to easily be able to change the transition duration, as well as the whole duration of the lower third, by typing in the respective durations. I have managed to use expressions with some sliders to animate it in:
    content(“Rectangle 1”).content(“Rectangle Path 1”).size
    t1 = inPoint;
    t2 = t1+effect(“Transition”)(“Slider”);
    t3 = effect(“Duration”)(“Slider”)-t2;
    t4 = effect(“Duration”)(“Slider”);
    v1 = [0,effect(“Width”)(“Slider”)];
    v2 = [effect(“Height”)(“Slider”),effect(“Width”)(“Slider”)];
    ease(time,t1,t2,v1,v2);
    and if I change the last line to
    ease(time,t3,t4,v2,v1);
    I can get the out animation that I want (which is basically reversing the in animation). However, I don’t know how to get the whole thing to animate in, and then animate out. I can only have one or the other. I am very new to expressions, so any guidance/other solutions will be much appreciated!
    Dan Ebberts
    replied 5 years, 7 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    February 10, 2021 at 8:23 pm
    Try replacing the last line with this:
    time < t2 ? ease(time,t1,t2,v1,v2) : ease(time,t3,t4,v2,v1);
