Activity Forums Adobe After Effects Expressions Using Expression to Check Text String Match
  • Using Expression to Check Text String Match
    Posted by Roland R. kahlenberg on December 6, 2023 at 12:12 pm
    So, a Text Layer, “Layer Text” has the following Text String –
    Comprehensive Meals
    TODAY ONLY
    When checking if the string has changed, in another layer, I’ve got this Expression –
    const a = thisComp.layer(“Layer Text”).text.sourceText;
    if(a == “Comprehensive Meals” + “\n” + “TODAY ONLY”) {“YES”} else {“NO”}
    I should be getting a result of YES but instead I’m getting a NO. Why?
    I’ve done this ages ago but I seem to have forgotten something critical.
    TIA
    Tom Morton replied 2 years, 9 months ago 2 Members · 3 Replies
  • Tom Morton
    December 6, 2023 at 12:30 pm
    You’re using the wrong new line operator. By default, AE uses “\r” rather than “\n” (although “\n” will work as a new line if you output it in a string)
    so the below for me gives me a “YES” instead.
    var a = thisComp.layer(“Layer Text”).text.sourceText;
    if(a == “Comprehensive Meals\rTODAY ONLY”) {“YES”; } else {“NO”; };
    Note that you don’t need to concatenate the strings with the \r operator, you can just use a single string.
  • Roland R. kahlenberg
    December 6, 2023 at 12:36 pm
    AWESOME!!!
    Thanks Tom!!!
  • Tom Morton
    December 6, 2023 at 2:32 pm
    no worries 🙂
