Activity Forums Adobe After Effects Using Expression and Slider Effect to Animate Number Count
  • Using Expression and Slider Effect to Animate Number Count
    Posted by Lindsay Simpson on December 22, 2014 at 3:14 pm
    I am building an animated counter in After Effects CC 2014 using the expression below with a slider effect on a text layer.
    Math.round(effect(“Slider Control”)(“Slider”))
    This works great! Except that it limits out at 1,000,000 and I need final count of over 9,000,000.
    Does anyone know of a trick to overcome this count ceiling using this effect? Or another means to achieve the same goal?
    Lindsay Simpson replied 11 years, 9 months ago 2 Members · 2 Replies
  • John Cuevas
    December 22, 2014 at 3:24 pm
    Instead of using a slider control, use an angle control. Type your numbers into the angle(it will convert it to degrees, on the effect, but not the number output). Angle doesn’t have a limit like slider does.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Lindsay Simpson
    December 22, 2014 at 5:22 pm
    Thanks for taking the time to provide feedback. I will try the angle effect, but also found that this thread helpful: https://forums.creativecow.net/thread/227/25998
