Activity Forums Adobe After Effects Using Essential Graphics to Switch Between Layers
  • Using Essential Graphics to Switch Between Layers
    Posted by Thomas Roddis on July 24, 2025 at 10:34 am
    Hey there!
    I have a project which requires outputting several videos for different screens, each being a different view of a scene. Imagine a 360 VR experience but shown on screen on walls.
    I am currently using essential graphics to control a menu switch which then sets a certain layer’s opacity to 100 depending on which view needs to be rendered. The problem I am having is the render times. IT IS TAKING FOREVER to render as AE seems to be evaluating the layers that are set to 0 opacity. The reason I set up this system is so that I can have one master comp, where I can alter in & out points and it updates every screen, as they all use a mastercomp with a different menu switch option set by essential graphics.
    I’m looking for ideas on how to output 7 different screens that all need the same timings but require different layers for rendering. I have a system that works, but because I’m using OpenEXR, it is just not very performant at all, and I suspect even though only 1 layer is visible, it is still processing all 7.
    All help appreciated,
    Tom
    John Martin
    replied 1 year, 1 month ago
    2 Members · 1 Reply
  • John Martin
    July 24, 2025 at 1:07 pm
    Hey here’s a solution i’d try: Instead of toggling visibility within one master comp:
    -Create 7 separate compositions (one per screen/view).
    -Each comp contains only the relevant layers for that view (delete or disable others).
    -Use one master precomp for syncing animation/timings.
    -This ensures only necessary EXR layers are loaded for each render, potentially resulting in a crazy performance boost.
    lemme know if you appreciate the help. good luck 🔥
