Using DV project properties to edit HDV/AVCHD project
Is there any reason why I should not use DV WS project properties to edit an HDV or AVCHD project and then change it to HDV 1080i when it comes time to render?
The reason I do this is I typically use 4 tracks to edit a multicam project of HDV and AVCHD media using Ultimate S, and I find that this method allows a reasonably workable and smooth preview rate.
The output is for both DVD and bluray (rendered out using their respective templates). The quality seems fine, but I was wondering if there was a strong technical reason against doing this.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
