Activity Forums Apple Final Cut Pro Legacy Using drop frame and non-drop frame in the same sequenc
  • Using drop frame and non-drop frame in the same sequenc
    Posted by Huaw123 on November 5, 2006 at 9:53 pm
    I’m a newbie and I’m trying to find out if it is okay to use both drop frame and non-drop frame in the same sequence? I am an assitant editor working on a project shot in SD and HDV. The problem is 95% of the footage is in drop frame. When trying to capture via a Kona card to edit in DVCHDPro 100 using the 720p 59.94 preset, the clips are changed from drop frame to non-drop frame as indicated by the colon between the seconds and frames. When capturing through Firewire, FCP’s helpful scene detection “feature” will keep the drop frame timecode but sometimes slices up scenes that have no scene breaks making new clips where none exist. I had a problem after using Media Manager to collect a project onto a portable hard drive with some clips shifting in and out points. I was told it was because I mixed drop frame and non-drop frame clips in the same project. So I think there is a problem but it would be nice if it were confirmed.
    We are working on a new Mac Pro using FCP 5.1.2 and a KONA LHe card. We are also using a JVC 720p BR-HD50 deck. The editor may need to work in two different places so the Media Manager issue is something we have to consider. This is for broadcast.
    If it doesn’t matter if we use both drop frame and non-drop frame in the same project then we can move forward. Otherwise, any suggestions would really be appreciated.
    Thanks in advance,
    Lynne
    Kent Kajino replied 19 years, 10 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    November 5, 2006 at 10:20 pm
    TC is just a set of numbers assigned to locating frames on a tape.
    DF and NDF on sources do not matter.
    The Timeline can be either NDF or DF and it will remain independent of the sources.
  • Kent Kajino
    November 7, 2006 at 7:04 am
    I’ve seen some of what you’ve described.
    I had a large project that was shot mainly in DF, but with some footage in NDF. The sequence was NDF.
    I had some (but not many) recaptured footage being shifted some, but I didn’t have enough time to determine if it was the recapture or the media manager that introduced it. The project was ported into FCP from Adobe PP via Automatic Duck, so there were too many variables in my case.
