Activity Forums Adobe After Effects Using DPX files… usage questions
  • Using DPX files… usage questions
    Posted by Aaron Bear on May 22, 2009 at 8:04 pm
    Hey all,
    Ive read the artilce on the Cineon files; https://magazine.creativecow.net/article/cineon-files-what-they-are-and-how-to-work-with-them
    but Im still unsure as to how to accurately work with this kind of file.
    Two of my questions are;
    1. Can you export a Cineon .DPX file with alpha(project settings are set to 32-bit (float) and workspace as none)?
    2. What is the proper way to adjust the Cineon converter so Im viewing the footage in the right way? I apply the filter but Im not sure how to use the settings. If I understand the tutorial on using the Cineon files correctly, you use the exposure control to clip the values so they dont go about 1.0 for RGB. Is this correct?
    I have never worked with an HDR image such as this, so any help would be greatly appreciated!
    Thanks in advance!
    -Aaron-
    “Wherever you go, there you are”
    Todd Kopriva replied 16 years, 11 months ago 2 Members · 1 Reply
  • Todd Kopriva
    May 22, 2009 at 9:01 pm
    Using the Cineon Converter effect is only recommended if you need to animate the values over time. The recommended ways of working with Cineon and DPX footage items are these:
    – (recommended) Use color management.
    – (OK) Interpret the Cineon/DPX files using the Cineon Settings dialog box (which you get to through the Interpret Footage dialog box).
    – (only if you need to animate settings) Use the Cineon Converter effect.
    See “Importing and interpreting Cineon sequences” and “Cineon footage items”.
    There’s a detailed, step-by-step set of instructions for digital cinema workflow using color management in the “Color management workflow in After Effects CS4” paper.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
