Activity Forums AJA Video Systems Using Downconvert from Kona 2 to SD
  • Using Downconvert from Kona 2 to SD
    Posted by Mpigott on June 24, 2008 at 5:20 pm
    Hi! I’d like to take some XDCAM footage off an XDCAM timeline
    in FCP and sent it out to a composite SD DVD recorder by using the
    Secondary Downconvert (525i 29.97) on a Kona 2.
    Problem is; it seems that it will only output in the three output
    video mode and not send out the video as composite.
    Are there any tricks to this.
    Mpigott replied 18 years, 2 months ago 2 Members · 2 Replies
  • Gary Adcock
    June 24, 2008 at 5:57 pm
    [mark pigott] “Problem is; it seems that it will only output in the three output
    video mode and not send out the video as composite. “
    Set the AJA control panel to output via composite and use the “green” component channel for the connection to your deck.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Mpigott
    June 24, 2008 at 6:01 pm
    [gary adcock] “Set the AJA control panel to output via composite and use the “green” component channel for the connection to your deck.”
    Thanks, after I messaged, I read the manual.
    I jumped the gun. All is good.
