Activity Forums Adobe After Effects Expressions Using distance to control transparency
  • Using distance to control transparency
    Posted by Gerard Bowden on July 14, 2013 at 5:24 am
    Hi, Im trying to control the transparency of an object by using the distance of it with another object. Any help would be much appreciated. thanks
    object1=transform.position;
    object2=thisComp.layer("object2").transform.position;
    distance=length(point1, point2);
    tMin=250;
    tMax=50;
    value1=0;
    value2=100;
    transform.opacity =linear(distance, tMin, tMax, value1, value2);
    Dan Ebberts replied 13 years, 2 months ago 2 Members · 1 Reply
  • Dan Ebberts
    July 14, 2013 at 7:40 am
    Something like this should work. If what you want is just the opposite, switch value1 and value2.
    point1=transform.position;
    point2=thisComp.layer(“object2”).transform.position;
    distance=length(point1,point2);
    tMin=50;
    tMax=250;
    value1=100;
    value2=0;
    Dan
