Activity › Forums › Adobe After Effects Expressions › Using databases/Excel with expressions
Posted by Eric Goldstein on May 23, 2011 at 7:57 pmHi,
Does anyone have any experience/thoughts on incorporating data from an external source with expressions? I’d like to bring in some position, rotation information to apply to a comp.
Eric
Eric Goldstein
Giraffe Film Company
Los Angeles
eric@giraffefilm.comEric Goldstein replied 15 years, 4 months ago 3 Members · 3 Replies -
Dan Ebberts
May 23, 2011 at 8:09 pmUnless you need a live link and the amount of data is really small, a script would probably be much better suited to the job. A script can read a tab or comma delimited spreadsheet file.
Dan
Kevin Camp
May 23, 2011 at 8:28 pmyou may also be able to hack the clipboard data that you get when you copy keyframes in ae…
if you paste that keyframe data into a text editor, you can then hack the data, possibly by simply copy/pasting from a spread sheet. then select all in the text editor, copy and then paste that keyframe data into a layer in ae… no scripting necessary.
how useful that is really comes down to what you need to do… if you have a lot of keyframe data in a spreadsheet that you need on a single layer in ae, this may be pretty effective. if you have to do this for many layers, or as a frequent process then creating a script or expression may be worthwhile.
here’s a sample of what the clipboard data looks like for position:
Adobe After Effects 8.0 Keyframe Data
Units Per Second 29.97
Source Width 50
Source Height 50
Source Pixel Aspect Ratio 1
Comp Pixel Aspect Ratio 1Transform Position
Frame X pixels Y pixels Z pixels
0 0 500 0
150 500 0 0End of Keyframe Data
you would simply modify the data for frame, x, y and z pixels to create new keyframe data, then paste that into a layer in ae (note, you can adjust the tabs if you wanted the data columns to line up correctly, but it’s unnecessary)
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Eric Goldstein
May 26, 2011 at 1:15 amThank you both for your thoughts. They were very helpful.
Best,
Eric
Eric Goldstein
Los Angeles
