Activity Forums Compression Techniques Using Compressor to convert Standard Definition files to HDV
  • Using Compressor to convert Standard Definition files to HDV
    Posted by Caroline on April 3, 2006 at 3:07 pm
    I will be taking an Online onto final cut.
    Some of the footage is shot as HDV and some at SD – Standard definition. I will set the project as HDV and digitise the SD footage as SD and resize once it is in the system. However somebody mentioned to me that on the final cut pro system there is a software called Compressor, which means you can convert the SD files to HDV or somehow change the compression. Does anyone know out there how Compressor works.
    Any advice would be greatly appreciated.
    Kind Regards,
    Caroline orme
    Ben Waggoner replied 20 years, 5 months ago 2 Members · 1 Reply
  • Ben Waggoner
    April 5, 2006 at 6:08 am
    Compressor supports some pretty advanced optical flow based resampling and scaling. It does a better job of upsampling to HD than most software. However, it takes some tweaking, and can be extremely slow – potentially multiple hours per minute of source on a dual G5.
