Activity Forums Apple Final Cut Pro Legacy Using Compressor in FCP
  • Using Compressor in FCP
    Posted by Abhishek Sharma on April 25, 2009 at 3:10 pm
    Hi There,This is Abby.I am New to Apple final cut pro.Well my sequence is ready on FCP and i want to Convert it into the best DVD video using Compressor in FCP.SO What should i do after clicking on FILE>Export>Using compressor. as there are lota of options avaialbe.I want a DVD out of ma project having the best quality.Plz suggest something
    Abhishek
    Josh Olenslager replied 17 years, 4 months ago 2 Members · 1 Reply
  • Josh Olenslager
    April 25, 2009 at 4:03 pm
    Abby,
    in Compressor select the DVD folder under Apple Groups. There a a number of options dealing with total project length (Best for 90 minutes for example). Drag the entire folder — audio and video setting — onto your sequence in the holding window. Make sure that your burning disk is big enough to hold all the media you need for the DVD. (If your sequence is super long, like 3 hours or something, you’ll probably need to export in 2 pieces using in/out points or use a dual layer.) The setting will create files that can be taken into DVD studio where you can build your menus, etc. For HD disks you’ll probably want to select the H.264 setting.
    Josh
    Digital Media, Thought Equity Motion
