Activity › Forums › Compression Techniques › Using Compressor I need mpeg2 with audio & video in same file.
Posted by Juan Francisco on August 21, 2005 at 7:46 pmHI,
I can’t see where I can set up Compressor1 to make a mepg2 file with audio and video as parrt of the same file.Thanks
Juan.
Charles Simonson replied 21 years ago 4 Members · 7 Replies -
Craig Seeman
August 22, 2005 at 11:55 amHaven’t tried it myself but in Compressor 2 in the Inspector under Encoder/Extras Tab there’s a “Multiplexed MPEG-1/Layer 2 Audio” check box with the discription “Select this to create an MPEG-2 Trasnport stream with multiplexed audio.
Juan Francisco
August 22, 2005 at 11:29 pmCould you be more specific. I have 2 separate files that i need to compress and combine for DVD studio pro. One file is a .m2v file and the other is an aiff file. Please, if you could help, that would be great. thanks
Juan
Craig Seeman
August 23, 2005 at 3:16 amI don’t think Compressor 1 could mux mpeg2. One more reason to upgrade. Compressor 2 is a major improvement over Compresson 1 IMHO.
Charles Simonson
August 23, 2005 at 4:25 amCheck out either ffmpegX or BitVice Helper.
https://www.innobits.se/pubdown/BitViceHelper.sit
https://homepage.mac.com/major4/ -
Lukeinvt
August 24, 2005 at 10:35 pmWhy? As far as I know DVDSP would prefer that you import your video and audio files seperatly. If they share the same file name (example.m2v and example.aiff) DVDSP will know that these 2 files are linked.
Charles Simonson
August 25, 2005 at 2:08 amMPEG-2 Program Streams (where the audio and video are muxed) are good for when you don’t need to build and burn a complete DVD, and sending just the MPEG-2 movie (for instance, for QCing) where it can easily be played back is more beneficial.
