Activity › Forums › Compression Techniques › using compressor for local cable tv broadcast
  • using compressor for local cable tv broadcast
    Posted by George Sloan on January 6, 2011 at 10:10 pm
    Can any one help?
    Using the process described from FAQ…entitled…
    “How do I create a Standard DVD from an HD Project?
    From your finished HD timeline:”
    Works great but no good for delivering on DVD to broadcast using an older encoder/modulator.
    Which takes the dvd material and squishes/elongates the images for standard mgeg2.
    I have talked to the station and the modulator’encoder manufacter… they know nothing but standard def
    4:3 mpeg 2 which is what they want on DVD. I would like a higher quality product since I am shoooting in 1O80i. Shoot I give up and just shoot and or edit in sd. (cannot buy new hardware at this time)
    George
    Craig Seeman replied 15 years, 9 months ago 2 Members · 3 Replies
  • Craig Seeman
    January 6, 2011 at 10:21 pm
    Do they want DVD-Video or a file on a DVD? BIG difference. Outside of public access I can’t imagine any asking for DVD-Video. Normally it would be MPEG2 Program Stream for Standard Def.
  • George Sloan
    January 6, 2011 at 10:56 pm
    This is basically a public access…
    yes i have been delivering DVD video and they just put on antyhing I give them…which is part of the problem. Their mpeg2 encoder just sees it as 16X9 distorts it squished 4X3 and broadcast it
    i am currently compressing using compressor. to address this very issue
    I am using custom settings….
    Under steam usage there are 2 possible choices…Generic or sd dvd. I chose Generic this time.
    under aspect ratio i chose 4×3….
    Could this be the elusive.”.MPEG2 Program Stream for Standard Def”
    you mentioned?
    am i just distorting it for them…so that don’t need to distort it for me?
    Thanks George
  • Craig Seeman
    January 7, 2011 at 12:02 am
    [george sloan] “This is basically a public access…”
    OK. Makes sense since many public access channels accept DVD video.
    [george sloan] “Their mpeg2 encoder just sees it as 16X9 distorts it squished 4X3 and broadcast it”
    In Standard Def, 16×9 is a change in pixel shape (the flag for it) so that 16×9 and 4×3 are both 720×480 so if you’re making an anamorphic (SD 16×9) DVD their encoder probably just sees is as 720×480 and makes it 4×3.
    The trick is forcing to be letterbox rather than anamorphic. I’m trying to remember how to do this in Compressor for DVDs as it’s not standard.
    Try this.
    Duplicate a DVD setting in Compressor.
    Under Encoder button Video Format tab change Aspect Ratio to 4:3
    Under Geometry button Output Image Inset (Padding) change Padding to Preserve source aspect ratio
    Open the file in QuickTime and see if it shows the Letter Box. If you don’t have MPEG2 play component then check the file in VLC Player.
    If you have an HDTV with a DVD Player attached then after burning the DVD check it in that. You should see a letter box black bars. If it were anamorphic it’ll fill the screen and not show the black bars. You don’t want that.
