Activity Forums Apple Final Cut Pro Legacy Using Comnressor to convert SD files to HDV
  • Using Comnressor to convert SD files to HDV
    Posted by Caroline on April 3, 2006 at 3:08 pm
    I will be taking an Online onto final cut.
    Some of the footage is shot as HDV and some at SD – Standard definition. I will set the project as HDV and digitise the SD footage as SD and resize once it is in the system. However somebody mentioned to me that on the final cut pro system there is a software called Compressor, which means you can convert the SD files to HDV or somehow change the compression. Does anyone know out there how Compressor works.
    Any advice would be greatly appreciated.
    Kind Regards,
    Caroline orme
    Caroline replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
