Activity Forums Apple Final Cut Pro Legacy Using clips of different field dominance
  • Using clips of different field dominance
    Posted by Bobby Hall on July 27, 2016 at 5:02 am
    When I edit a project in FCP 7 using files from my DSLR camera, I have to manually change the field order in the browser from Upper (Odd) to None due to FCP not recognizing the correct field dominance.
    I also have some .mov files I downloaded from Footagecrate.com and when I import them in the browser it says they’re Upper (Odd) or Lower (Even). Should the field dominance of these clips be changed to None or are they actually most likely Upper and Lower? And if they are, should I leave them that way in the browser or change them to None? Is it okay to mix clips of different field dominance in a sequence?
    Bobby Hall replied 9 years, 9 months ago 2 Members · 6 Replies
  • David Roth weiss
    July 27, 2016 at 1:06 pm
    In order to see fields you must have an I/O card displaying a true video signal to a video monitor – if you’re working on a laptop or with computer monitors only you’ll be guessing about the field order of the stock footage, which could bite you later if you create DVDs or broadcast the project.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Bobby Hall
    July 28, 2016 at 10:31 pm
    Some of the clips are 720×480 .mov files with a pixel aspect of NTSC – CCIR 601, with PNG codec, and they say “Lower (Even)” in the browser.
    Other ones are the same except they’re 1920×1080.
  • Bobby Hall
    July 29, 2016 at 7:15 am
    I forgot to mention that the 1920×1080 clips say “Upper (Odd) in the browser. Lower and Upper both mean interlaced, right? And is it okay to use those clips in my progressive sequence where 99.9% of the footage I’m using is progressive? My project is a video for the web.
  • Bobby Hall
    July 29, 2016 at 8:04 am
    I read on another forum that sometimes FCP 7 misinterprets progressive footage as interlaced. And then this person said you shouldn’t change the sequence settings to progressive (which I assume is “None”) because then half the fields will be discarded. Is this true? I thought if your footage is progressive and FCP misinterprets it as Upper (Odd), then you should change the field dominance to “None”, so that both your clips and sequence settings are “None”. Can someone explain which one is correct?
  • David Roth weiss
    July 29, 2016 at 6:19 pm
    Bobby,
    If all if your footage was progressive and was being misinterpreted as interlaced, switching to “None” would fix the issue… But, you have a mixture of progressive and interlaced, so there’s no magic bullet one click fx for you in FCP Legacy.
    If the majority of your footage is progressive, your seq settings should be set to None, but you’ll “most likely” have to deinterlaced the remaining interlaced footage, because FCP Legacy does not deal with field mismatches well at all. FYI, Premiere and all modern NLEs do a much superior job.
    FYI, FCP’s deinterlace filter also sucks, so you may have to use a third party deinterlacer.
    David Roth Weiss
    Los Angeles
  • Bobby Hall
    July 29, 2016 at 10:57 pm
    Thanks guys. If some of my clips are 720×480 .mov files with a pixel aspect of NTSC – CCIR 601, does this mean the frame is being stretched horizontally a little bit? I thought 720×480 was only for DVDs (non-square pixels) and a computer reads them as 640×480.
