Activity › Forums › Adobe After Effects › Using Cinema4D files in AE – video texture not working
  • Using Cinema4D files in AE – video texture not working
    Posted by James Tango on October 6, 2015 at 10:21 pm
    I have a somewhat obscure problem right now – I have an object in Cinema 4D that has a video texture on it with transparency (a hologram). It displays fine in Cinema 4D, but it doesn’t show up properly in AE. I’ve spent the last few hours searching the web high and low for a way to have this display properly in AE, but have found nothing so far.
    Here’s what they look like in each program:
    https://i.imgur.com/Ojbhzno.jpg
    I’ve posted this in the Cinema4D forum as well. Any help would be much appreciated!
    View post on imgur.com
    Ashish Gupta replied 10 years, 12 months ago 3 Members · 4 Replies
  • John Cuevas
    October 7, 2015 at 3:21 pm
    How are you bringing it into AE?
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • James Tango
    October 7, 2015 at 4:22 pm
    I have the original *.c4d file imported into AE, and it’s running using the Live3D update. Whenever I save the file in Cinema 4D, it automatically updates in AE.
    When I view the footage item in AE it shows up properly, but as soon as I drop it into a comp the hologram loses its transparency.
  • John Cuevas
    October 7, 2015 at 7:46 pm
    Does it need a C4D tag that AE needs to see to interpret correctly? Otherwise I would suggest rendering out the hologram layer with an image buffer from C4D and composite it in AE.
    ThinkCK
  • Ashish Gupta
    October 8, 2015 at 8:02 am
    I dont see any reason for it to not work properly. Can you share your c4d file with the video texture?
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
