Activity Forums Apple Final Cut Pro Legacy Using Cinema Tools-Useful or Nightmare?
  • Using Cinema Tools-Useful or Nightmare?
    Posted by Richard Boddington on November 15, 2006 at 11:49 pm
    I have FCP 4 here to edit a project shot on 35mm, and transfered to HDSR 24fps in 4:4:4.
    I want to offline the proj using DVCAM versions of each of my transfer masters, make an EDL, and auto assemble the final in a tape-to-tape HDSR suite.
    It has been suggested in this forum that I can just edit this as a 29.97 project, spit out the CMX EDL from FCP, and then have the post house re-conform the EDL to 23.98 using some magic that they have. The post house has confirmed that they can do this, but there will be cases where I make an edit on a 3:2 pulldown frame in my offline. This can cause a flash frame that will need to be fixed by stopping the assembly.
    Then there is Cinema Tools, which I have never used. Can any one give me their work flow for using Cinema Tools to offline a 24fps film show?
    How did you set up the FCP project?
    Did you strip off the 3-2 pull down with Cinema Tools on the source footage after you loaded it all in? You did you remove it from the final time line edit only?
    How did you export the EDL for final assembly?
    Richard
    Sean Oneil replied 19 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    November 16, 2006 at 2:49 am
    I only used Cinema Tools to convert the ALE into a FCP Batch list. Beyond that…OH…and I used it to convert a 29.97 EDL to a 23.98 EDL. But other than that, I feel that it really is only intended for works that will require a negative cut.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Sean Oneil
    November 16, 2006 at 5:36 am
    [35mmGuy] “I make an edit on a 3:2 pulldown frame in my offline. This can cause a flash frame that will need to be fixed by stopping the assembly.
    Did you strip off the 3-2 pull down with Cinema Tools on the source footage after you loaded it all in? You did you remove it from the final time line edit only?”
    Two things:
    1. If you do edit in 29.97, FCP lets you tag your clips with “Film Safe” thus preventing you from making edits in places which will later cause flash frames.
    2. You can use CT to perform an inverse telecine before editing. But rather than doing that, you can actually capture the footage directly as 23.98 using a Kona or Blackmagic card. You just need to identify the A frame. That way when you do the batch re-capture from HDCam SR, it should come in flawlessly since the framerate isn’t changing.
    Sean
  • Sean Oneil
    November 16, 2006 at 5:45 am
    BTW, I just remembered CT won’t let you do a reverse telecine with DV footage. For some stupid reason, it assumes that DV footage must be 3:2:2:3 advanced pulldown, not regular 3:2 pulldown. So you’d have to convert it to uncompressed or JPEG first.
    Go with the Kona/Decklink solution if you can. Definitely the best workflow.
    Sean
  • Richard Boddington
    November 16, 2006 at 6:05 am
    Two things:
    Sean,
    Tell me more about this option, how do you do it? What are the settings?
    Another excellent idea, thanks. I’ll look around for the card, the Blackmagic card may come in handy for future projects as well.
    Richard
    Sean
    November 16, 2006 at 5:09 pm
    Does any one else know about Film Safe? I have looked all over the FCP menus, and all over the help, and I can’t find a thing on this (see below).
    I would love to know where it is and how to set it up.
    Thanks in advance.
    Richard
    [Sean ONeil] “35mmGuy] “I make an edit on a 3:2 pulldown frame in my offline. This can cause a flash frame that will need to be fixed by stopping the assembly.
    Two things:
    2. You can use CT to perform an inverse telecine before editing. But rather than doing that, you can actually capture the footage directly as 23.98 using a Kona or Blackmagic card. You just need to identify the A frame. That way when you do the batch re-capture from HDCam SR, it should come in flawlessly since the framerate isn’t changing.”
  • Tunaking
    November 16, 2006 at 8:54 pm
    Sean,
    Not true. People use every day. It was designed to do this. It’s been doing this since it was Film Logic.
    >>Not true at all.
    >>You have to watch out with the Kona/Decklink solution. When the clips are reversed they remember their 29.97 timecode (they are not converted to 23.98). If you look at the timecode window in FCP for the clips, they jump timecode numbers. If you plan to online in HD this can cause problems, because you can make edits in your offline that happen above frame 23 (like frame 29). Use caution.
    Sean
  • Sean Oneil
    November 16, 2006 at 9:39 pm
    [TK] “Not true. People use every day. It was designed to do this. It’s been doing this since it was Film Logic.”
    Actually CT 2.2 it doesn’t work. The option to pick the A frame is greyed out. But yes I was wrong in the sense that they seemed to have fixed it with CT 3. I apologize.
    [TK] ” If you look at the timecode window in FCP for the clips, they jump timecode numbers. If you plan to online in HD this can cause problems, because you can make edits in your offline that happen above frame 23 (like frame 29)”
    You can use “Modify->Timecode” and change it to 23.98 TC.
  • Sean Oneil
    November 16, 2006 at 9:55 pm
    Also, if you capture and edit at 23.98 from a Kona or BM, you can still use the EDL conversion route. It still doesn’t prevent you from doing that because the 29.97 TC is still intact so you can make a 29.97 EDL. Additionally, you won’t be making any bad edits that will cause a flash frame because the editing is in a 23.98 timebase.
    Another possible solution is to have the HDCam deck output as 1080i60 and use the same pulldown removal method during the online as you do in the offline.
