Activity Forums Adobe After Effects Using Channel>3D Glasses in AE 6.5
  • Using Channel>3D Glasses in AE 6.5
    Posted by John Sackey on June 22, 2006 at 4:10 pm
    Hi all
    I am having a bit of trouble getting the desired effect in AE with the 3D Glasses effect. I have some footage of a band and I want to create some shots where the background is seen as normal video but the band appear as B&W anaglyphs. So far I have gone this route:
    1 Create a comp with the Tinderbox two tone newsprint effect applied.
    2 Place comp 1 into a new comp and use masks to separate the band members from the rest of the footage.
    3 I drop the original footage behind the masked layer; Newsprint band members on normal background, so far so good.
    4 When I apply the 3D Glasses effect to the newsprint layer I choose the newsprint comp as the source for each view. I want to use Balanced Coloured Red/Blue as this gives the best result (B&W image with the red/blue offsets). The problemis that all of the balanced options seemto force a black background in the newsprint layer, cutting off the background layer.
    The non balanced r/b r/g options don’t force the black background but cause a tint to the white areas.
    Anyone got any advice?
    John
    John Sackey replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
