Activity Forums VEGAS Pro Using Canon PF24 with Sony Vegas 12
  • Using Canon PF24 with Sony Vegas 12
    Posted by Rob Cioffi on March 21, 2015 at 5:17 pm
    I’m trying to use PF24 (AVCHD) footage for a 24p project. Is this possible? I tried converting the footage with Handbrake but some of the ghosting is actually worse. Thanks in advance!
    Camera is HF10.
    Rob Cioffi replied 11 years, 5 months ago 3 Members · 6 Replies
  • Aaron Star
    March 22, 2015 at 4:35 am
  • John Rofrano
    March 22, 2015 at 11:56 am
    PF24 is wrapped in 29.97 fps. Try using a 29.97 project and just render to 24p at the end. This will give Vegas Pro a change to remove the pulldown. I don’t know if it will do it correctly but it’s worth a shot.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rob Cioffi
    March 22, 2015 at 6:00 pm
    Thanks guys. John the render at 24p did not seem to work. Aaron I will give it a try but what I was hoping for was a 1 step GUI based solution like this one using Handbrake:
    https://youtu.be/_OD1tCAnlGM?t=1m51s
  • John Rofrano
    March 22, 2015 at 6:34 pm
    [Rob Cioffi] “John the render at 24p did not seem to work.”
    Yea, it was worth a shot but I kinda thought it wasn’t regular pull-down. You need program that knows how to deal with this proprietary format.
    ~jr
  • Rob Cioffi
    March 22, 2015 at 7:05 pm
    There are some references to Cineform Neoscene being able to do this but it’s no longer available.
  • Rob Cioffi
    March 22, 2015 at 9:30 pm
    It seems like AVS Converter 8.3 is doing the trick. Thanks.
