Activity Forums Blackmagic Design Using Canon HF100 with Blackmagic Intensity Pro
  • Using Canon HF100 with Blackmagic Intensity Pro
    Posted by Jabari Osaze on January 16, 2011 at 2:22 am
    Greetings:
    I am trying to use my Canon HF100 with a Blackmagic Intensity Pro capture card to stream to Ustream. Is anyone out there using this configuration? While the Producer (regular and pro) recogizes the card as “Decklink” the image I get is black. It seems the software is working, I have 2 Logitech c910s hooked up via usb which seem to be working fine. Can anyone help here?
    Jabari
    Mike Caruana replied 15 years, 7 months ago 3 Members · 2 Replies
  • Chris Pearse
    January 17, 2011 at 9:38 am
    Hi Jabari,
    I’m afraid I’m not familiar with the software you mention, but to rule out any compatibility issues with the software itself, I would suggest performing some tests using our Media Express software just to eliminate this as a possibility.
    The key things to make sure are set correctly, are your input in Control Panel->Blackmagic Control Panel->Set Input, and the capture format in whichever software you use to capture. In Media Express this is set under Edit->Preferences->Project Video Format.
    I would also suggest contacting the Blackmagic Design support office in your region for more help if you have not already done so. Our email support form can be found here:
    https://blackmagic-design.com/support/contact/
    And the support numbers can be found on the company page here:
    https://blackmagic-design.com/company/
    Chris Pearse
    Technical Support Consultant
    Blackmagic Design EMEA
  • Mike Caruana
    January 17, 2011 at 3:04 pm
    What output are you using on the camera?
    You can’t use USB. There’s no live output. It either has to be HDMI or HD-SDI.
    Based on the issues I’m having with my Vixia, try setting the capture input to 1080 59.94i. Every other setting seems to give me a blank screen.
