Activity Forums VEGAS Pro Using camcorder pass-through vs. ADVC device for Sony Vegas capture/external preview
  • Using camcorder pass-through vs. ADVC device for Sony Vegas capture/external preview
    Posted by Rick Anvican on July 17, 2015 at 11:52 pm
    Hi all,
    I have been offered a functional Sony DSR-PD150 and would like to use it as a DV pass-through device for capturing from and outputting to analog devices. Is anybody still using pass-through on a camcorder and would like to comment on the signal quality when compared to a dedicated capture device like the Canopus ADVC devices? Thanks in advance.
    John Rofrano replied 11 years, 1 month ago 2 Members · 3 Replies
  • John Rofrano
    July 18, 2015 at 6:28 pm
    [Rick Anvican] “Is anybody still using pass-through on a camcorder and would like to comment on the signal quality when compared to a dedicated capture device like the Canopus ADVC devices? “
    It should be just as good as the ADVC-100 but not as good as the ADVC-300 with TBC. If you weren’t going to spend the money for the ADVC-300 or you don’t need Time Base Correction, then go for it. It should work great.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rick Anvican
    July 18, 2015 at 10:46 pm
    [John Rofrano] “It should be just as good as the ADVC-100 but not as good as the ADVC-300 with TBC. If you weren’t going to spend the money for the ADVC-300 or you don’t need Time Base Correction, then go for it. It should work great.”
    Thanks John, I did expect that camcorder DV pass-through would perform a bit under the ADVC devices but I do hope that the camera being a 3CCD model, the quality of its converter should be good.
  • John Rofrano
    July 19, 2015 at 4:12 pm
    You’re welcome. Lots of people use a DV cameras pass thru for analog conversions so you should be fine.
    ~jr
