Activity Forums Adobe Premiere Pro Using Bridge to Premiere with a hiccup in between
  • Using Bridge to Premiere with a hiccup in between
    Posted by Douglas Morse on April 5, 2013 at 1:55 pm
    Using an SD card, Adobe Bridge launches automatically and allows me to rename files as it copies them to a harddrive. However, in the field, I copy cards to individual folders on a portable harddrive. I then want to import this footage from the portable harddrive to my main drive using Bridge to rename the files upon import.
    Bridge doesn’t want to see my folders as cards and doesn’t think I need to import the footage. Is there a way to force it to do this? Or use premiere to import the folders renaming the files as it brings in the footage?
    Douglas Morse replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
