Activity › Forums › Adobe After Effects Expressions › Using bounding box in extendscript (and using it to create a mask path)
Posted by Emre Mutlu on June 28, 2022 at 6:52 pmHi there,
Can i reach a layer’s bounding box via ExtendScript? I can explain what i’m trying to do with those steps :
– Import a vector drawing in a comp
– Get the bounding box of this layer to create mask path within it
I’ve added a screenshot to illustrate it.
Emre Mutlu replied 4 years, 2 months ago 2 Members · 4 Replies -
Dan Ebberts
June 28, 2022 at 9:15 pmAre you talking about scripting or expressions? With expressions you would just click on your vector layer with the pen tool to create a mask point and add an expression something like this to the Mask Path:
r= sourceRectAtTime(time,false);
p = [[r.left,r.top],[r.left+r.width,r.top+r.height/5],[r.left,r.top+2*r.height/5],[r.left+r.width,r.top + 3*r.height/5],[r.left,r.top+4*r.height/5],[r.left+r.width,r.top+r.height]];
createPath(p,[],[],false)
It would be similar but a little more involved with scripting.
Emre Mutlu
June 28, 2022 at 9:49 pmThank you Dan. I tried your way and it worked.
I was talking about scripting. I post here because can’t find a scripting topic. How could i do it with script? Could you please explain the logic in this so that i can understand it 🙂 Also is there a way to create the mask point without using pen tool?
Dan Ebberts
June 28, 2022 at 10:54 pm<div>The script version would be like this:</div>
var myLayer = app.project.activeItem.layer(1);
var r = myLayer.sourceRectAtTime(0,false);
var myMask = myLayer.property("Masks").addProperty("Mask");
var myPath = myMask.property("Mask Path");
var myShape = myPath.value;
myShape.vertices = [[r.left,r.top],[r.left+r.width,r.top+r.height/5],[r.left,r.top+2*r.height/5],[r.left+r.width,r.top + 3*r.height/5],[r.left,r.top+4*r.height/5],[r.left+r.width,r.top+r.height]];
myShape.inTangents = [];
myShape.outTangents = [];
myShape.closed = false;
myPath.setValue(myShape);
Basically you’re just using the layer’s left, top, width, and height extents as provided by sourceRectAtTime() to calculate where you want the mask vertices to be. I just took a shot at it based on your diagram. Since the mask is all corner points, you can provide empty arrays for the in and out tangents.
