Activity Forums Apple Final Cut Pro Legacy Using Both XLR Inputs on my Camcorder- Bad Idea?
  • Using Both XLR Inputs on my Camcorder- Bad Idea?
    Posted by Jared Smith on March 25, 2011 at 5:14 am
    Hey guys
    I am shooting quite a few talking head interviews next week. I will be a one man show and want to make it as organized and simple as possible. It is 13 lawyers who have squeezed me into their schedule so I really don’t need to be messing with too much equipment. So, here is my question:
    I will be using either an JVC HM100 or a Panny HMC150 (I split equipment with about 10 other guys so I am not sure which one I will have). Either way, they both have 2 XLR inputs. I wanted to run a wired lav straight into Input 1 and then have my boom (NTG-2) overhead and running into Input 2.
    Is this going to cause any issues during the shoot or in post (FCP 7)? Is there something smarter to do here? I have a Zoom H4n but was really not wanting to mess with bringing more equipment into the equation…
    Any suggestions are greatly appreciated.
    thanks
    jared
    Dan Brockett replied 15 years, 6 months ago 8 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    March 25, 2011 at 5:37 am
    Why include two XLR inputs if it’s bad to use both? No, it’s GOOD to use both.
    Shane
  • David Roth weiss
    March 25, 2011 at 6:55 am
    [Jared Smith] “Is this going to cause any issues during the shoot or in post (FCP 7)?”
    This is the method that gives your editors the most flexibility in post.
    I was a location sound engineer for seven years during one of my many incarnations in this business, and that’s precisely how I’d do it.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Rafael Amador
    March 25, 2011 at 10:46 am
    Sure, is the way to go.
    Even if you would have only one mic, is convenient to record your audio in two channels.
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    March 25, 2011 at 11:53 am
    Ya, keep the levels a little lower in one channel.
    Also, I find when you have many interviews in a short time, Using a boom is easier b/c there is no fussing around with them and the lav.
    They walk in, they sit, and almost ready…
    Chris Tompkins
    Video Atlanta LLC
  • Ken Jones
    March 25, 2011 at 1:15 pm
    [Chris Tompkins] “Also, I find when you have many interviews in a short time, Using a boom is easier b/c there is no fussing around with them and the lav.”
    My thoughts exactly!
  • Jared Smith
    March 25, 2011 at 2:59 pm
    that is exactly what i want to do but i am petrified of not getting good audio somehow if i don’t have two different options…
  • Bernard Newnham
    March 25, 2011 at 4:01 pm
    THe bit you need to worry about is getting the levels right before you start – microphones give out quite surprisingly different basic output levels. So, make sure you’ve done checks with realistic voice levels before you start recording, and it’ll all be wonderful.
    Oh – and if you should decide to run in auto, see whether the autos on the two channels are separate. If they use a common auto sensor, and one track is very loud, the other will disappear – as discovered by me the hard way on a helicoper some years ago.
    B
    bernie
  • Dan Brockett
    March 25, 2011 at 5:18 pm
    Only recording interviews with a boom mic is common but it also boxes you into a corner. What if there is too much ambient noise that begins to show up mid-interview? What if the person’s voice just doesn’t sound good on the particular boom mic you are using? I highly recommend the approach you are taking, always record with two mics if you can. It gives you that most wonderful option in editing, choice.
    Many people will sound better on a lav than a boom and vice-versa. Many times a boom mic will pickup ambient sound from the elevator that is 150 feet away, or that conversation coming through the walls three offices down. Lavs can really save your rear when shooting on location.
    When shooting on a sound stage, using a boom only makes a lot more sense to me because there will probably not be any ambient issues. Using a boom only on location because you are too lazy to take the :15 it takes to clip on a lav is nuts, you are in the wrong business. Same with using wireless lavs for sit down interviews, it is the epitome of laziness. Use a wired lav and always use two mics when you can. It’s called best practices and it is what the most talented videographers and sound mixers do. You can’t do sound in a half-assed manner or it will bite you.
    Cheers,
    Dan
    A Producer Who Is Also A DP? Yep, that’s Me.
    http://www.danbrockett.com
