Activity Forums Adobe Audition Using both Audition and Soundbooth in CS4
  • Using both Audition and Soundbooth in CS4
    Posted by John Matheny on February 16, 2011 at 9:12 pm
    I am primarily using Premiere Pro CS4 but also have PP CS2 installed (with Audition). There are many instances in which I would prefer to use Audition for sound correction. Is there a way set things up to “Edit in Audition” from the edit menu. The edit menu in CS4 only has “Edit in Soundbooth” available.
    I have found some “work-arounds” to use Audition but they are a pain and quite time consuming. Does anyone know if this can be done.
    Andrew Devis replied 15 years, 5 months ago 2 Members · 1 Reply
  • Andrew Devis
    March 12, 2011 at 8:12 am
    It was a feature we requested to be added back and returned with cs5. Unfortunately, it isn\’t available in cs4 🙁
    Andrew
    … because it’s all about stories …
