Activity Forums Boris FX using boris effects as a transition between ckpis without affecting the layer underneath.
  • using boris effects as a transition between ckpis without affecting the layer underneath.
    Posted by Jack Neiswanger on August 25, 2010 at 1:04 am
    Does anyone know how to use a boris efx, such as directional blur, as a transition between clips with alpha channels without it blurring the clip on the video track beneath the logos. Thanks, Jack
    jack
    Peter Mcauley replied 16 years ago 2 Members · 3 Replies
  • Peter Mcauley
    August 25, 2010 at 1:12 pm
    Hi Jack,
    You just need to make sure that you apply the blur filter to the track that you want to blur and not to the whole timeline. If this is not clear please let me know and I’ll help you to understand how it works.
    Cheers,
    Peter.
  • Jack Neiswanger
    August 25, 2010 at 1:53 pm
    Peter, give you me an example of how to do this. Thanks
    jack
  • Peter Mcauley
    August 25, 2010 at 3:31 pm
    Hi Jack,
    Exactly what program are you using … Boris RED, Graffiti or FX? Once I know I can send you a settings file that shows you how to do this. I’ll need your email address to send it to you. You can send that information to me privately at peterm@borisfx.com.
    Peter.
