Activity › Forums › Apple Final Cut Pro › Using blade tool and strange happenings to clip
  • Using blade tool and strange happenings to clip
    Posted by Lawrence Eaton on September 19, 2011 at 4:21 pm
    I used the blade tool, just now and after slicing and dicing through the primary storyline clip, the clip itself magnified.
    The clip is 100% by default and I haven’t done anything to it at the moment – no effects, transitions and the like…. squirrely.
    Have I accidentally turned on a setting that I can’t remember?
    If I deselect the clip afterwards and then return and select it, everything is ‘normal’ again.
    Puzzled,
    Lawrence
    Jeremy Garchow replied 15 years ago 2 Members · 3 Replies
  • Jeremy Garchow
    September 20, 2011 at 2:58 am
    [Lawrence Eaton] “the clip itself magnified.”
    You mean scaled?
  • Lawrence Eaton
    September 20, 2011 at 11:03 am
    Apologies Jeremy, I meant scaled.
    Lawrence
  • Jeremy Garchow
    September 20, 2011 at 5:56 pm
    [Lawrence Eaton] “Apologies Jeremy, I meant scaled.”
    No worries. Check the “crop” property in the inspector
