Activity Forums Maxon Cinema 4D using bitmap background
  • using bitmap background
    Posted by Alan Lacey on October 19, 2005 at 9:35 am
    Hi guys,
    I’m trying to do a simple animation (deformed arrows running along a spline) and composite this over a previously rendered C4D frame.
    The problem is that however I seem to set up the background image, the resulting renders display soft backgrounds.
    I’ve tried using a background object in a camera viewport, setting the required bitmap to the colour channel of a new material (sampling=none in it’s parameters)and applying the material to the bg object. results are soft.
    Setting a background image to one of the orthogonal viewports also results in similar softness. Is it not possible to set a similar bg image to a camera viewport?
    My output is for D1 720×576 (1.07 par) and the background image was rendered the same way.
    Am I missing something obvious here or do I really need to composite this simple animation in AE?
    Thanks for any help
    Alan
    Alan Lacey replied 20 years, 10 months ago 2 Members · 2 Replies
  • Moka-studio
    October 19, 2005 at 1:40 pm
    have you tried it setting the scene antialiasing to Best , otherwise only the geometry gets antialiased.?
    Is the resolution of the image correct?
    Did you try the scene in a new doc, with only the Backgound object, to see if the problem really has to do with the texture?
    The easiest would be to composite though…
    jean-pierre,
    http://www.moka-studio.com
  • Alan Lacey
    October 19, 2005 at 3:10 pm
    Thanks ‘Moka’
    aa was set to geometry but setting it to best doesn’t make any difference.
    I’ll try the ‘background only’ project as soon as I get a chance.
    Alan
