Activity Forums Adobe After Effects Using bevel layer style in AE causes flickering / scintillating
  • Using bevel layer style in AE causes flickering / scintillating
    Posted by Moog Gravett on July 24, 2014 at 1:43 pm
    Hi folks,
    I’m using the bevel layer style to create some chiseled looking text.
    The problem is, when I animate it in a scene, there are lines which kind of dance around the surface making it unusable.
    My setup is text in a precomp -> style applied to pre-comp.
    I can reduce the effect by making the text rounder, but this is not what I need.
    Any ideas?
    Cheers,
    Moog
    Moog Gravett replied 12 years, 1 month ago 2 Members · 3 Replies
  • Cassius Marques
    July 24, 2014 at 5:08 pm
    precompose again with “move all atributes inside..” option. Animate this new comp. Layers styles are applied after all transformations so they should allways be pre-comp’d.
  • Moog Gravett
    July 24, 2014 at 8:19 pm
    Ah, that makes sense. I’ll give it a go tomorrow.
    thanks for the reply,
  • Moog Gravett
    July 29, 2014 at 3:45 pm
    That worked beautifully,
    thank you for your help Cassius.
    Moog
