Activity Forums Apple Motion Using behaviors to create a “puzzle” effect
  • Using behaviors to create a “puzzle” effect
    Posted by Imari on September 19, 2005 at 9:37 pm
    Hello,
    The problem is this: I have a video clip duplicated in six layers. Each layer is masked off to break the image into different pieces…like a puzzle. What I want to do is begin with the pieces of video scattered across the screen and then return to their original position to complete the “puzzle”.
    I know that I can do this by keyframing and plotting each layer’s original x&y coordinates at the final keyframe, but is there some combination of behaviors (i.e., throw, reverse, negate) that can accomplish this task? I (wrongly) assumed that it should be simple as applying a throw and then applying a reverse behavior to the throw behavior… any ideas?
    Imari
    Imari replied 21 years ago 3 Members · 3 Replies
  • Bill Mcguire
    September 21, 2005 at 4:28 am
    how ’bout a throw effect, save it as QT, and playin it backward?
  • Jim Kanter
    September 21, 2005 at 7:29 am
    Try using motion paths. In M2 you can even add bezier control points (keyframes) to adjust the shape of the path.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Imari
    September 21, 2005 at 6:57 pm
    Thanks, Bill and Jim. I guess the play it backwards idea is probably the simplest way to achieve this… why didn’t I think of that?
