Activity Forums Maxon Cinema 4D Using background as texture?
  • Using background as texture?
    Posted by Andrew Okeh on January 8, 2012 at 12:38 am
    Hi! Could anyone help me out with an issue I’m having?
    I’m trying to make a clip where I make bricks rise up from the ground. I want the bricks to “stretch” the sidewalk as they rise up, as if the sidewalk was a carpet and the block was underneath it. How would I use the background texture and put it on the block to achieve this effect?
    Here’s what I have right now:
    https://img841.imageshack.us/img841/4374/77453203.png
    But it doesn’t look like it came out from the sidewalk. The textures I have on those blocks are just a picture of the sidewalk that I took earlier. It doesn’t really match up though.
    Thank you to anyone who helps me with this!
    Adam Trachtenberg replied 14 years, 8 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 9, 2012 at 8:43 pm
    You could frontal map the texture on the blocks and then bake the texture, but that will obviously only work for the top surface.
