Activity Forums Avid Media Composer using Avid Xpress DV with Apple compressor/ DVD studio pro 3
  • using Avid Xpress DV with Apple compressor/ DVD studio pro 3
    Posted by Edward Howard on June 14, 2005 at 8:50 am
    Hi there,
    I have just completed a DVD job using Avid Xpress DV (4.6), compressor (1.2.1) and DVD studio pro 3.0.2. I have had an issue with a handful of QuickTime reference files out of Avid Xpress when encoding with Apple Compressor which is both partial encodes and incorrect frame size of final MPEG2.
    Could someone please explain the best way to export out of Avid to DVD studio pro via compressor so I can see where I am going wrong.
    Cheers,
    Edd
    Edward Howard replied 21 years, 3 months ago 2 Members · 2 Replies
  • Todd Beabout
    June 16, 2005 at 8:51 pm
    [Edward Howard] “I have had an issue with a handful of QuickTime reference files out of Avid Xpress when encoding with Apple Compressor which is both partial encodes and incorrect frame size of final MPEG2.”
    I would suggest that you just export ONE reference file from Avid. The fact that you had a “handful” may have something to do with the problem. If you have the hard drive space and the reference files keep giving you a problem, you might should try to export a “self-contained” movie and then drag that into Compressor.
    I’ve had some weird problems trying to use reference files with Compressor also. You might also try letting DVDSP do the encode itself when you import the QT reference file. Or you could download a free demo of BitVice and see if you have better luck with that.
    Good luck.
    -Todd Beabout
    Vazda Studios
  • Edward Howard
    June 17, 2005 at 8:04 am
    Hi Todd,
    Thanks for the reply, I managed to finish the project at last using the exporting to a full quicktime movie methord. I’m just a bit annoyed because I just want thinks to work first time!
    Thanks again for your help.
    Cheers,
    Edd
