Activity Forums DaVinci Resolve Using Avid Color Control Panel And Toggling Through Resolve Processes
  • Using Avid Color Control Panel And Toggling Through Resolve Processes
    Posted by Chris Martin on January 31, 2012 at 4:54 pm
    Apologies if this has been addressed before but I did not see it…
    Test driving Avid Color Panel and wondering if it is possible to go from Resolve’s different processes (Config, Browse, Conform, Color…) by way of using the control surface buttons.
    Additionally, wondering if there is a way to have the GUI open/jump to the parameters currently being used by control surface. Example – I press the “windows” button to access the menu on control surface but the GUI does not jump from the “curves” tab to “windows.”
    I’m working from the premise the answer is “go buy the Black Magic Resolve panels for such performance” but wanted to make sure that was in fact the case.
    Cheers, Chris
    Tim Tyler replied 14 years, 7 months ago 3 Members · 2 Replies
  • Eric Johnson
    January 31, 2012 at 9:58 pm
    I don’t know about the Avid board, but for the Eclipse, if you are working in the Qualifier or the Window it will switch, but you can’t get to the blur or the key…. So you get some, not all… Also, I can get from all of the “rooms” to Color, but not the other way around. Which is a huge bummer…. That would be a really handy shift function…
    I realize that’s not a direct answer… But you can at least get a portion of what you are asking for w/o spending $30k, so that has to count for something…. Also, I tried out the Wave w/ Resolve, and had my hands on the Avid w/o the software and I have to say that if you can find a way to afford the eclipse, it is really worth it.
  • Tim Tyler
    February 1, 2012 at 1:34 am
    This PDF illustrates the control functionality in Resolve.
    https://www.blackmagic-design.com/media/1794141/DaVinci_Resolve_Avid_Artist_Color_Panel.pdf
    Tim
